what to do?
Old Aug 14, 2006 | 10:50 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by regency
and do you think the 02 Z06 cam would rock on with my truck?!!!! it seems to be almost identical with the cam your running, except the LSA its a little wider, a 117 i think
I think you'll definitely feel an improvement, and it'll idle like stock with that wide lsa. Combine that cam with a decent verter and you could have a nice budget combo.
Old Aug 14, 2006 | 11:10 PM
  #22
regency's Avatar
i am wanting a yank or fuddle 3000 bad very bad. i saw that time and was like ohhh man, then i remembered that you have a 4 wheel drive, so thats pretty good, just for now until i kill or almost kill this motor im gonna get the z06 cam i think, and probably spray the hell outta it
Old Aug 15, 2006 | 04:56 PM
  #23
I haven't run it in it's current configuration, but I went 15.6@89.5mph with this cam, tune, K&N FIPK, Gibson Shorties and Catback, and 33" tall BFG All Terrains (285/75R-16) The tires totally killed my 60' times (2.4).
Not sure what it'll run now, but my current tires are 31" tall, and I also have added StainlessWorks longtubes and catted y-pipe, 05 efans, and 160* stat. Swapped the K&N for a Volant w/ ram air, but I doubt there's any gain there. I'm sure I'm still in the 15's though...a mild verter would probably bring me into the high 14's.
I just don't understand why your times are so low. With those mods, I would have thought you could easily muster a low 14 to high 13.
Hell TxSilverado' ECSB turned out a 13.8xx with his untouched high mileage 5.3L with only bolt-ons. The engine hasn't ever been apart. An he's all N/A.
I think there is a lot more to be had with your set-up. You just haven't put the right combonation together yet. It's all trial and error.
I know that your 4wd, but you can take it out of 4wd. The extra weight would be about the same when comparing a 2wd ECSB truck to a 4wd RCSB truck. At least I would think.
Good luck.
Jim
Old Aug 15, 2006 | 05:11 PM
  #24
Dave68RT's Avatar
well i ran slower after long tubes. hope that makes you feel better. and the weather is really really shitty for the track.
