what to do?
Old Aug 13, 2006 | 01:28 AM
regency's Avatar
thought about nitrous and 3000 stall, but i think that might come with a free busted tranny
Old Aug 13, 2006 | 09:34 PM
It won't hurt the tranny. Go with a stall, 1-2 vette servo & OD sonnax servo, and shift kit. That will actually prolong the life of the tranny.
Jim
Old Aug 13, 2006 | 10:28 PM
regency's Avatar
ok so here is what i decided!!!!
get a cam either the 6.0 stock cam (LQ9) or the cam that lilreddevil is selling, with the springs and pushrods of course. and a 3000 stall if i can find one cheap enough for my budget!!!
Old Aug 13, 2006 | 10:37 PM
budhayes3's Avatar
PT's Slowest Truck
I thought that the 4.8-6.0's all used the same cam...at least they used to. Either way, if you're looking for more power, I wouldn't go with any stock truck cam. litreddevil's cam will yield you some nice gains in the upper RPM's, but you'll definitely need that stall to make it all work together. (ld's cam is the Comp 216/220 right?)
Old Aug 13, 2006 | 10:41 PM
regency's Avatar
yes sir its that one, and i was told by a buddy that knows his stuff very well that he saw a 4.8 crew cab with the 6.0 cam go around 14.7 or 14.8 in bad weather so i know it'll do better in my truck, but just lookin around right now
Old Aug 14, 2006 | 08:09 PM
regency's Avatar
found this, is it too big!
218/225 @ .050
.532/.529 Lift
112 LSA
Old Aug 14, 2006 | 10:10 PM
budhayes3's Avatar
PT's Slowest Truck
218/225 @ .050
.532/.529 Lift
112 LSA
That cam will definitely want a stall and some expert tuning...with all that duration and a tight lsa, there is a ton of overlap, which you'll be able to hear through it's lopey idle characteristics. Those specs almost remind me of the GM Hot Cam (219/228 .525/.525 112).
BTW, I did some research in Will Handzel's "How to Build High Performance Chevy LS1/LS6 V-8's" book, and found some cam specs for ya:
00 and up 4.8 & 5.3 = 191/190 .457/.466 114
02-03 LQ4/LQ9 = 196/207 .467/.479 116
So as you mentioned, the 6.0 cam is a bit bigger than the 4.8/5.3 cam
Old Aug 14, 2006 | 10:27 PM
regency's Avatar
bud what does your truck run?!!!!
Old Aug 14, 2006 | 10:28 PM
regency's Avatar
and do you think the 02 Z06 cam would rock on with my truck?!!!! it seems to be almost identical with the cam your running, except the LSA its a little wider, a 117 i think
Old Aug 14, 2006 | 10:47 PM
budhayes3's Avatar
PT's Slowest Truck
I haven't run it in it's current configuration, but I went 15.6@89.5mph with this cam, tune, K&N FIPK, Gibson Shorties and Catback, and 33" tall BFG All Terrains (285/75R-16) The tires totally killed my 60' times (2.4).
Not sure what it'll run now, but my current tires are 31" tall, and I also have added StainlessWorks longtubes and catted y-pipe, 05 efans, and 160* stat. Swapped the K&N for a Volant w/ ram air, but I doubt there's any gain there. I'm sure I'm still in the 15's though...a mild verter would probably bring me into the high 14's.
