Well it isn't good when you can spin the crank pulley bolt
Old Oct 3, 2008 | 06:58 PM
Mangled03gmc's Avatar
Baltimore Whore
Unhappy Well it isn't good when you can spin the crank pulley bolt
With your fingers to take it out. Tonight I fig I would change my front seal since the last blown belt ruined it, change the pan gasket also, cause it was leaky.. Went to put the socket on the bolt, it spun effortlessly, like no it was just sitting in there,then I removed it with my fingers.. I am going to pull the pulley off now, pray to the man that it didn't *** the end of the crank up, but my luck it did.. That may be the reason im puking belts... Keep ya fingers crossed for me guys... I will post back fo sho
John
Old Oct 3, 2008 | 07:02 PM
brobradh77's Avatar
I take it you didnt pin it? I hope you didnt mess it up.
Old Oct 3, 2008 | 07:10 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
scarey stuff good luck!
Old Oct 3, 2008 | 07:42 PM
hirdlej's Avatar
It'll be fine
Old Oct 3, 2008 | 07:47 PM
skeet's Avatar
damn bro, good luck and lets hope it didnt fug it up
Old Oct 3, 2008 | 07:48 PM
dewmanshu's Avatar
Moderately Differentiated
yeah, the belt thing may be solved. Are you pinning it? Most stories end good if it comes loose from the front. I lost a thrust bearing...that story ended bad.
Old Oct 3, 2008 | 07:49 PM
phasemaster1's Avatar
Talk to me Johnny, you havent called back!
Old Oct 3, 2008 | 07:54 PM
Baltimore Whore
I broke a puller strap, it seems it is still on there pretty good, duno if that is good or bad, I hope it is good. Well see in a few min's, YES THAT BITCH IS GETTING PINNED, like a 2 dolla ***** in the back of a 75 chevy van.. My fingers are crossed... Phases I iget wit ya in a few. Thanks bro
John
Old Oct 3, 2008 | 07:55 PM
Baltimore Whore
Please elaborate for me, my mind is racing, so your saying if it was loose and It came out easy I could be ok??????????????? DEWY
John
Old Oct 3, 2008 | 08:19 PM
XLR8NSS's Avatar
Adkoonerstrator
I'd leave it on and just pin it.
