Well it isn't good when you can spin the crank pulley bolt
Old Oct 6, 2008 | 02:31 AM
  #21
laynlow77's Avatar
i doubt you screwed anything up!
Originally Posted by Raffman
Pullers aren't the problem, the balancer install tool is................Had to make one.
same here... threaded rod, couple washers and an old socket and youre in business.
Old Oct 6, 2008 | 08:21 AM
  #22
hirdlej's Avatar
I just went to a local Fastenal store and brought in my original crank pulley bolt. Told them I wanted a new bolt that was one an inch and a half longer. Bought a special hardened washer as well. Put some oil around the crank snout and got the pulley started with the new bolt. put the factory bolt back in (new one) and drove it home with the impact gun at 200 ft lbs.
Old Oct 6, 2008 | 10:19 AM
  #23
Raffman's Avatar
I bought threaded rod from Fastenal, a thrust bearing from Kaman Bearing, couple nuts and washers, welded one nut to the end of the rod.... your're in business, the correct way to install.
O yeah almost forgot, an old wrist pin for a spacer.
Old Oct 6, 2008 | 11:49 AM
  #24
laynlow77's Avatar
thats exactly what mine looks like. go buy it, and you should be able to make at least 1 extra and sell it.
5.3Okasai
Mar 9, 2022 01:07 PM
chevyl33
Aug 24, 2015 08:21 AM
bigsapper
Jul 28, 2015 12:56 AM
blownss27
Jul 20, 2015 08:59 AM
GreyChevy
Jul 7, 2015 08:57 PM
