Wanted - C4 Trans advise
Old May 10, 2004 | 11:13 AM
Default Wanted - C4 Trans advise
Any transmission techs on the board ?
I would like to pick someones brain on a soft 1-2 shift on a C4
I am changing the vac mod and doing a trans service
I am doing a trans service and what to see if there is anything
I should do while the pan is off.
Old May 10, 2004 | 11:25 AM
Hit Man X's Avatar
Doesn't the Ford C4 use a servo/piston for the 1-2 shift? Superior makes a heavier apply servo for it as does someone else I think. From my memory it uses the forward clutch pack for 1st, then forward+band for 2nd, and forward and direct for 3rd. It's a very basic design just like the TH350 (what it's similar to somewhat)
Do you have a built valve body in it? Manual...automatic...reverse manual?
Old May 10, 2004 | 11:31 AM
No - stock trans - 81k - I got a new vac mod to put in - is adjustable
I plan on dropping the pan Tues night
While I was in there .....??
It has an soft 1-2 shift - but doesnt do it all the time.
Most of the time it is slight, easy take offs.
On more aggressive take offs - most of the time shifts OK - but not always.
Any suggestions.
Thanks for the repsonse Hit
Old May 10, 2004 | 11:45 AM
Hit Man X's Avatar
Oh wow a stock C4! LOL I hardly ever seen one not behind a Fox framed Ford now that's fully built.
I think that vac modulator should allow you to set shifts...
If you're feeling up to it, a TransGo is only like $55 for the C4. http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
That will get your shifts as firm as you want them.
Also it could be the band is getting old and worn...
Old May 10, 2004 | 11:52 AM
I wanted to do something - if poss with out blowning it apart
Yep bone stock
Old May 10, 2004 | 11:57 AM
Hit Man X's Avatar
Oh well all you'd do is drop the valve body and swap a few springs and open the feed holes in the seperator plate. Valve bodies on 3 speeds are laughablly simple. Tranny stays in the vehicle so there's not a whole lot of tearing down. I believe that the TransGo has some way to raise WOT shift points...at least in their AOD kits they have that.
Where are ya located?
Old May 10, 2004 | 12:24 PM
Thanks Hit
I am West of Chicago in the burbs.
I will check into the transgo kit - kinda of what I was thinking...
Old May 10, 2004 | 12:28 PM
Hit Man X's Avatar
Oh well you're a bit far for me to assist in the install! LOL
Lemme know if you have any more problems.
Bumpers
Aug 4, 2024 09:44 PM
KyleW707
Jul 29, 2015 08:17 AM
grantpo
Jul 15, 2015 12:21 PM
Black-Syde
Jul 6, 2015 02:12 PM
Nimoryan
Jul 5, 2015 03:50 PM
