Walbro Priming issue figured out ?
Old Oct 6, 2010 | 04:56 AM
Bigbus's Avatar
Default Walbro Priming issue figured out ?
Im looking at replacing the oem intank with a 255 from walbro, did a search and keep finding threads about them being troublesome prime wise and having to crank 2 or 3 tries to start.
I would just assume keep the stocker if im going to encounter this issue. can anybody shed some light on which is the model to get ? i know the 255 has several sub modlels.
basically i want to upgrade it, but dont want to have the prime issue. any guys successfully swapped it out and not have any issues with this ?
id love to hear your advice.
Dan.
Old Oct 6, 2010 | 07:22 AM
smokeshow's Avatar
Mod with training wheels
Installing a check valve inline with the pump eliminates the priming issue.
Old Oct 6, 2010 | 08:58 AM
dewmanshu's Avatar
Moderately Differentiated
Old Oct 6, 2010 | 04:55 PM
Bigbus's Avatar
Any links to said check valve or is it just a universal thing ?
Old Oct 8, 2010 | 07:08 AM
Bigbus's Avatar
bumpidy
Old Oct 8, 2010 | 09:53 AM
smokeshow's Avatar
http://www.summitracing.com/parts/MOR-23875
I believe I used something like that. Keeps the fuel from running back out of the lines once the pump shuts off.
Old Oct 8, 2010 | 10:41 AM
Atomic's Avatar
I have a gauge for that
I have never had an issue with mine. When the pump shuts off it drops maybe 5 psi then slowly drains.
Old Oct 17, 2010 | 12:07 PM
overdrive's Avatar
My son had issues with a new Walbro in that the check on the outlet of the pump was bad and would drain pressure back to the tank immediately. If he waited more than the 3 sec that the pump runs to build pressure and stops, he would not have any pressure and the engine was hard to start.
We pulled the check out of the old Walbro that failed and switched into the new pump and all is well.
Randy
XL7
May 5, 2022 01:48 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
