Victory is mine!!!
Old Jan 31, 2010 | 02:53 PM
03 BLACKOUTSSS's Avatar
Default Victory is mine!!!
I have been chasing a squeak for weeks now. Originally, I thought is was the belt going bad, changed it, squeak went away. Great. Nope, not so much, about 1K later, the squeak is back. Changed the belt again, squeak went away again, maybe it was just a crappy belt. Ahhhhhh notsomuch. It came back again within about three days. Finally got some heater hose, the squeak is coming from behind the water pump pulley. I converted from clutch to efans a while back, but I still have the same pulley (with the thread sticking out where the clutch fan threaded on). I am assuming that I need a new water pump (its not leaking or anything, jsut squeaking). My question is can I use one that was designed for efans from the factory? Is it possible because the pump isn't leaking, that I can just change the pulley? Any insight is appreciated.
Old Jan 31, 2010 | 03:04 PM
budhayes3's Avatar
PT's Slowest Truck
I was under the impression that the pulley was pressed on, and the 05+ water pumps that I've seen still have the threaded nub on the pulley, so I'll bet that they're the exact same part. I doubt that just changing the pulley would cure anything anyway, unless the pulley was damaged or nicked and causing a problem with the belt. If you suspect the noise to be coming from the water pump, it would probably be the front bearing that is giving you the problem if anything...
Old Jan 31, 2010 | 03:11 PM
Okay then, a pump change is in order. I would love to go electric, but thats a bit on the big $$$ side.
Thanks man.
Old Jan 31, 2010 | 03:44 PM
budhayes3's Avatar
PT's Slowest Truck
You got it man...and I'd stick with a stock pump personally, not a fan of electric pumps for a daily driver.
cheyenne383
Nov 13, 2015 09:24 AM
Wrecker 426
Oct 6, 2015 05:52 PM
Tuckin15s
Sep 23, 2015 09:35 PM
whitelazer
Sep 22, 2015 09:38 PM
MikeD.
Sep 18, 2015 09:55 AM
