Very Very Very Weird!!!! Need All Help Possible!!
Old Nov 9, 2007 | 09:49 AM
  #21
TouchOfEvil04's Avatar
Is he getting alot of KR out of the hole?
FWIW my truck ran a 14.9 dead on every run before i did my motor swap. Yet on the street i would beat people running as fast as 13.7's all day long. Noone believed me i ran a 14.9 unless they were friends who had seen it first hand.
I however never got anything scanned to see what the problem was as i did a motor swap fairly early on.
Old Nov 9, 2007 | 10:41 AM
  #22
zippy's Avatar
Ok, converter problem or not, he is only trapping 100mph. Even with the launch issue fixed he's going to be hard pressed to get better than a low 13. I'd say he's got a tuning or fueling issue. Not that he doesn't have a good tuner, just that there is likely a tuning issue at that time. He needs to get someone to log his run and I'd bet he'd find the problem. An example of a problem he may have is not going into power enrichment. With my truck after a bit of playing I found that if I don't let the truck run long enough before I get to the tree and launch it, I won't get power enrichment until half way through second gear, but if I let it run for about 1 minute before I get into the water box, power enrichment works perfect and I'm about .3 quicker without changing anything...???
Old Nov 9, 2007 | 11:32 AM
  #23
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
His trap speed is still low, he should be in the 103/104 range to run a mid/high 12.
Old Nov 9, 2007 | 03:10 PM
  #24
riodealpewter's Avatar
hey its me the guy with the problem. i stalled it 2200 and launched and didnt hook and got a 2.4 60ft. then i tried 1600 and launched and hooked but got a 2.1 60ft. dont know whats up but im gonna check it out on tuesday. me and my tuner are gonna tune the f**k out of it again.
Old Nov 9, 2007 | 05:04 PM
  #25
1slow01Z71's Avatar
Is your truck lowered alot?
Old Nov 9, 2007 | 08:23 PM
  #26
yeah its a 5/5 drop home made and with air shocks in the rear. i can adjust the airshocks when i want.
Old Nov 9, 2007 | 08:50 PM
  #27
trever1t's Avatar
2nd fastest 5.3 ECSB
How much weight does the system add to your truck? Compressor?
Old Nov 9, 2007 | 08:53 PM
  #28
dirt track racer 81's Avatar
dont know how much of a problem that it could cause but check and make sure the brake torque management is turned off
Old Nov 10, 2007 | 12:53 AM
  #29
the airshocks arent like air bags, no compressor. it just has a valve like the tires and i put air when i want to lift it. and also all the torque management was taken off. well thats what i told my tuner. whats BRAKE TORQUE MANAGEMENT?
Old Nov 10, 2007 | 12:56 AM
  #30
Another form of TM that kicks in while the brakes are applied and gas given at the same time.
