Vacuum leak help!
Old Mar 24, 2016 | 12:31 PM
02Sierra2500hd's Avatar
Registered User
Default Vacuum leak help!
I recently replaced the intake manifold gaskets on my 2002 lq4 and I can still hear a vacuum leak and still have rough cold starts. I had a lean code causing random misfire code and the intake gasket fixed that bit I can't find the other leak. I tried spraying brake clean and had no luck
Old Mar 24, 2016 | 01:53 PM
terravast4's Avatar
do a smoke test on it
Old Mar 24, 2016 | 03:45 PM
11 Second Club
I chased a vacuum leak for a week recently, took the intake off multiple times, never found anything at all... finally decided to swap the intake it's self, I found 2 wrecked bottom injector o-rings (the spare intake had flex-fuel injectors so I had to swap them)... replaced the o-rings, codes went away, truck runs great and all the fuel trims are correct now... I tried brake cleaner and even ether, neither would show up in the idle speed...
brads99xtreme
Mar 25, 2016 12:17 PM
Wyttrash96
Mar 24, 2016 06:28 PM
02Sierra2500hd
Mar 23, 2016 10:30 AM
2002_Z28_Six_Speed
Mar 20, 2016 09:49 PM
TAPyvehc93
Mar 20, 2016 11:08 AM
