vaccuum brake bleeders?
Old Mar 22, 2007 | 12:05 PM
SSSBLKOUT's Avatar
Default vaccuum brake bleeders?
http://www.nationaltoolwarehouse.com/xq/asp/prodid.15957/TID.{F62E6765-B394-4BE3-BB41-BE6B9A6F6157}/qx/product.htm
Does these things work? it says that it bleeds 2 qts per minute, that seems like good suction, no?
Old Mar 22, 2007 | 01:33 PM
negativeswitches's Avatar
i could not tell you cause the link dosent work
-Erik
Old Mar 22, 2007 | 06:16 PM
truckmann's Avatar
I got a pressure bleeder to do mine. I haven't used a vacuum one before, but the pressure deal worked great. The one I got is a Motive products power bleeder.
http://www.motiveproducts.com/
Old Mar 22, 2007 | 09:10 PM
SSSBLKOUT's Avatar
now it should work if you copy and paste.
Old Mar 22, 2007 | 09:29 PM
truckmann's Avatar
Wholly crap! The pressure bleeder I bought didn't cost that much...I was thinking I was gona see like a good old mighty vac that you can pick up anywhere for like $30. I guess for that price it better get all the air out.
Good luck getting you brakes working properly.
Old Mar 22, 2007 | 09:42 PM
bigbadwolf54's Avatar
13 Second Truck Club
http://www.sears.com/sr/javasr/produ...id=00942276000
http://buy1.snapon.com/catalog/item....re&dir=catalog
I havent used the one you posted, but have used both of these and yes they work..as long as you keep fluid in the resevoir and the seal tight..both of these actually pressurize the resevoir and then use vacuum to suck out the fluid at the bleeder. But the hand held mighty-vacs will usually work so I see no reason the one you posted wouldnt.
Old Mar 23, 2007 | 06:09 AM
SSSBLKOUT's Avatar
I was gonna buy the first one that you posted, the sears link, but I realized that I don't need the capacity to bleed 3 cars worth of fluid. I hope the one I bought works just as well.
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
kmcn47
Sep 17, 2015 01:12 AM
Alco
Sep 4, 2015 04:08 PM
