uh oh! faint squeek noise coming from rear...
Old Jan 13, 2006 | 01:04 PM
Fogle07's Avatar
prob a rat riding with you or maybe the leaf springs
Old Jan 13, 2006 | 01:18 PM
SSlow 4.8's Avatar
lol no.. neither of those
i had the *** end jacked up and let the tires rotate... squeeking around the rotor on the passenger side.. the pads are still around 50% or so, im not really sure what it is anymore
Old Jan 13, 2006 | 02:48 PM
nonnieselman's Avatar
soo did you not take the tire off? could it be the seal for the axle? or is it a metal-on-metal squeak? heck i went ahead and replaced the rotors, pads, and parkin brake shoes on mine,, they where cheap enough, and then i put all them bearings in there.. whew that was fun!
Old Jan 13, 2006 | 09:40 PM
SSlow 4.8's Avatar
ya i had the tires off... i think it might be a brake thing.. ill figure it out sometime.. this weekend is my bday.. so im taking a break, lol.
Old Jan 13, 2006 | 11:17 PM
StrokerAce03's Avatar
When my rear pads wore out they would squeak while driving. When I changed the pads it went away, but that might've been because I cleaned all the dust and **** out when I did it.
Old Jan 16, 2006 | 06:19 PM
SSlow 4.8's Avatar
ya.. i thought tht too.. thats actually what i did before the u-joint thing, it went away and than came back after driving just a little bit...
im thinking it might be time for new rotors and pads in the back anyways... if that doesnt fix it i think im going to change the diff. fluid for the hell of it.
Old Jan 16, 2006 | 06:59 PM
Flick5959's Avatar
check the e brake pads they might be worn down and need to be replaced. that should fix it.
Old Jan 17, 2006 | 06:34 AM
Fogle07's Avatar
yea have you ever changed the emergency brakes?
Old Jan 17, 2006 | 10:28 AM
EvilChevy's Avatar
It's prolly the rear axle seal. It doesn't cost much but putting it in is a pain ....
Old Jan 17, 2006 | 03:34 PM
budhayes3's Avatar
PT's Slowest Truck
I'll almost bet that it's the e-brake shoe rubbing the inside of the rotor...it's actually very common, and there's a tsb on it. The e-brake shoe clip snaps, the shoe shifts, rubs the drum part of the rotor and squeaks. Same thing happened to mine a few years back. The new e-brake shoes come with new, re-designed clips.
superchomper2003
Aug 26, 2015 09:39 AM
chevy6.0fan
Aug 20, 2015 07:10 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
