Two performance packs for 2006 silverado
Just an FYI. This is showing up on the 2006 model info thought it was interesting.
This is the RPO NHT:
VortecMax Performance Pack, includes (LQ9) Engine, Vortec high-output 6000 V8 and door badge that reads "Vortec Max", (M70) Transmission, 4-speed automatic, super duty, (GT5) Rear axle, 4.10 ratio, (G80) Differential, locking, heavy-duty, rear, (ZX3) Suspension Package, Ride-Control, (NP8) Transfer case, electronic Autotrac, (KC4) Cooling, external engine oil cooler, (KNP) Cooling, external transmission oil cooler, auxiliary, and (Z82) Trailering equipment, heavy-duty
1 - Requires CK15753 or CK15543 Models. (QJM) or (QJP) Tires must be ordered. (P25) Wheels must be ordered. Option content within this package may not be substituted or deleted. - Not available with (Z71) Suspension Package, Off-Road.
They still have the RPO B4V:
Standard Performance Edition, includes (LQ9) Engine, Vortec high-output 6000 V8, (M32) Transmission, 4-speed automatic, heavy-duty, (GT4) Rear axle, 3.73 ratio, (Z60) Suspension Package, High-Performance, (G80) Differential, locking, heavy-duty, rear, (NW7) Traction assist system, electronic, (KC4) Cooling, engine oil, (KNP) Cooling, external transmission oil cooler, (Z82) Trailering equipment, heavy-duty, (UK3) Sound system feature, steering wheel mounted radio controls, (QR9) Wheels, 4 - 20" x 8.5", cast aluminum, chromed, 5-spoke, (QSS) Tires, P275/55R20, touring, blackwall, (ZAN) Tire, spare P265/70R17, blackwall and 17" Wheel, steel, spare
1 - Requires CC15753 Models. - Option content within this package may not be substituted or deleted. Not available with (ZY2) Paint, two-tone, (DPN) Mirrors, outside rearview, power adjustable, heated, manual folding and extending, (B2E) Silverado Limited Edition or any (SEO) Special Equipment Options.
Also the SS is only going to be available as a 2WD option.
SO, I wonder what the pricing is going to be on these options???? Basically, 3 extended cab trucks with the LQ9 engine in them.
Also they are showing different trim packages:
New Packaging Structure
1WT = Work Truck
1LS = LS
1LT = LT1 trim
2LT = LT2 trim
3LT = LT3
1WT = Work Truck
1LS = LS
1LT = LT1 trim
2LT = LT2 trim
3LT = LT3
Originally Posted by SEMOscrew
how bout some info on a vho crewcab. thats my ideal truck.
The B4V is only available on the 2WD extended cab (CC15753)
Originally Posted by XLR8NSS
What is the M70 transmission I wonder? Is that a code for any of the current transmissions? 4L85E maybe?
man those codes are confusing. so i could get the 6.0 in a 1500 4wd but not 2wd?
but for the extra cost of 4wd and the 6.0 package i could probably swap in a 6.0 w/ a turbo.
(B4U)TrailBlazer SS available on base (1SB) and uplevel (1SE) (1SE requires YC6), 2WD and AWD (with NR9 Transfer case) models, (LS2) 6.0L V8 (doesn't include DOD) (M70) 4L70E automatic transmission, (ZQ8) Sport suspension, (G67) Rear air suspension, (G86) 9.5" limited slip rear axle with (GT5) 4:10 ratio, (P55) 20" polished wheels, (QUB) P255/50R20 tires, (UJ6) Tire pressure monitoring system, Stabiltrak, stability control, (T96) Fog lamps, body-colored door handles, rockers and Mirrors, outside rearview, uplevel shifter, unique-front and rear fascias, grille, badging, IP cluster, front seats (8-way power driver), bright exhaust tip, perforated leather steering wheel, (N79) / (QTM) 17" spare tire and wheel and trailer wiring harness extension. Deletes body-side molding, side rails and luggage rack.
Adkoonerstrator
Hmmm.....good info. Seems GM realizes the need for a stronger trans than the 60E in the 1500s and maybe they are finally trying to rectify the problem even though the 70E is probably just a more beefed version of the 60E/65E.
Originally Posted by jdg
Looking at the Models available on the VortecMax Performance Pack (NHT) it's available only on the 4WD extended cab and the new 4WD crew cab short box(CK15543). Looks like you can get this one for the crew cab short box.
It sounds like just another battery on the market.
If they want "MAX" then make the LQ9 engine come equipped with a supercharger all stuffed into a reg cab, short w-base truck.
Just my 2-cents worth.
Jim
