transmission in 1996 tahoe
Pretty sure tahoes didn't change anything until 2000. They all use the 4l60. Trucks were the same from 96-98. So you should be able to look for those years at least.
But not positive if something did change.
i have a 4l60 from a 95 camaro that would most likely work, youd just have to use your output shaft and tail housing from your current tranny to convert it to 4x4. even have a 3000 stall torque converter to go with it. where are you located? the transmission is a fully built unit with only 3k miles on both.
zblee
Nov 11, 2015 12:41 AM
mitchellmade
Sep 27, 2015 08:27 PM
bluestang50
Sep 21, 2015 08:36 AM
1996, 4x4, 96, built, chevy, identify, kind, performance, put, tahoe, trans, transmission, transmissions, work, year
