transfercase fluid
Old Oct 31, 2013 | 05:18 PM
mattjones's Avatar
Default transfercase fluid
99 silverado 1500 4wd (nbs). it has the auto 4wd. ive read that some people run the autotrakk II. the question is do i have to? of can i use ATF like i always have? ive heard of people running both i already have ATF for it that i want to use since i read that people have ran both. does it really matter? 4wd gets used in winter seeing that i live in wisconsin right now.
Old Oct 31, 2013 | 05:27 PM
Atomic's Avatar
I have a gauge for that
I think you need the special fluid for that one. For the ones without the auto function you can use normal trans fluid.
Old Nov 1, 2013 | 12:39 PM
Suburbazine's Avatar
Auto 4x4 you have a silicon viscous clutch to consider. The thinner ATF will burn that t-case up in a heartbeat because the clutch will operate at higher temperatures than ATF is designed for.
The transfer case is not just an oil bath either, it includes its own low pressure pump and lubricating system. Wrong fluid = Failure
Old Nov 4, 2013 | 08:23 AM
mattjones's Avatar
thanks boys you saved me a T-Case! ran the autotrak
Old Nov 4, 2013 | 11:11 AM
geoffmt's Avatar
I found out the expensive way, you must run the autotrak fluid, I burnt out all my clutches, which by the way leave a very bad smell in your buddy's shop that lasts for days
Blwn99x
Mar 24, 2023 11:14 AM
drummer0415
11
Oct 24, 2015 08:16 PM
turbo6c3
Oct 5, 2015 06:11 PM
fortune46x
Sep 16, 2015 08:18 AM
97aztecgt
Sep 10, 2015 05:07 PM
