Trans Squeak when Shifter's Moved from D<->3
Old 01-14-2012, 07:40 AM
Rockafella's Avatar
Default Trans Squeak when Shifter's Moved from D<->3
01 Silverado, 6.0L blazayblah w/ a 4L80E/PT Yank 3000 installed. The truck can be running and sitting still and when you put it in drive all is well. If you try to go past drive, I hear a loud squeak like right when the shifter is midway between D and 3. Doesn't make the noise if putting the shifter in 2 or 1.
If you put the shifter from 3 to D then it may just be a loud quick squeak or it may be a 2-3 second squeak that's extremely loud. I have no idea what the heck it is and it's not a problem when driving normal and just throwing the truck in D and heading out. Part throttle shifts are great and wot shifts always chirp the tires on the 1-2 shift and snappy as heck on others.
Could it be the neutral safety switch not being aligned properly or is it something else? Any ideas would be greatly appreciated! Thanks!
shawn96gmc
05-17-2016 04:15 PM
thunder550
10-08-2015 04:53 PM
Ketis
07-23-2015 12:37 PM
Sdailey
07-13-2015 09:17 PM
Quick Reply: Trans Squeak when Shifter's Moved from D<->3
