Towing Question...
Old Apr 13, 2007 | 07:57 PM
bigredexpress99's Avatar
Default Towing Question...
Bet you wouldn't have guessed me asking this, but its really just for more reassuring than it is right or wrong.
I have an ls1 efan setup on my truck, controlled by the PCM with my own tune. Now here's the deal - I live in Nebraska where its FAIRLY flat. I've pulled a boat a few times, 100 degrees out, 90% humidity, without overheating.
Here's my concern. I'm road tripping to San Diego the last week of May. Going there empty, but GUARENTEED to come back with an 81 cutlass (the fullsize version) in tow on a trailer, and probably loaded down with other car parts.
Are the mountains going to cause any problems when coming back? I could just put the clutch fan on for peace of mind, but if I can do without the extra drag, I will......
Let me know what you all think!!
Old Apr 13, 2007 | 08:53 PM
nightrunner's Avatar
Mr. Obvious
if its possible id make the fans stay on the whole time the engine is running for safety, but otherwise you SHOULD be alright
Old Apr 14, 2007 | 12:57 AM
nonnieselman's Avatar
Just take the Clutch fan with you and if it starts heating up, throw the clutch fan on and shroud... a whooping 5 minute job..
We are goin to kentucky in a month or so. and ill be pulling a 16' Trailer with 4-5 4wheelers... im not sure what to expect but ill find out...
Good luck!
Old Apr 14, 2007 | 09:21 AM
2001si3rr@'s Avatar
I agree. If you don't already have an override switch to turn on the fans wire one in. If you could turn the fans on whenever you felt you needed it I think you will be ok. The efans by themselves are good enough for the 2005 and up trucks.
When the clutch fan starts to lock up its going to rob some of the power away from your engine, and you are going to need every bit of that in those mountains and hills! The efans are going to be your best bet.
Old Apr 14, 2007 | 01:46 PM
Originally Posted by 2001si3rr@
I agree. The efans by themselves are good enough for the 2005 and up trucks.
Yeah, thats a good point, but they also get the larger 34" core rad and a bigger set of fans. I'm in 04 with a smaller rad and fans designed for a car.....
maybe its a valid excuse for an 05 rad/fan swap.....
Old Apr 14, 2007 | 01:47 PM
any other opinions?
Old Apr 14, 2007 | 02:49 PM
ZZebes's Avatar
watch the gauge, keep your foot out of it, add some water wetter, watch the gauge, and oh watch the gauge
Old Apr 15, 2007 | 09:16 AM
2001si3rr@'s Avatar
Very true, I didn't even think of that.
Old Apr 15, 2007 | 09:17 AM
2001si3rr@'s Avatar
Great idea.... You got me thinking of doing this to mine now!!!
calsdad
Jun 14, 2023 11:07 PM
andrewlong
Nov 9, 2016 09:38 AM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
andrewlong
Sep 8, 2015 10:25 PM
