? Timing cover gasket set needed for 04 LQ9
Old Feb 11, 2012 | 09:39 AM
Petey62782's Avatar
MASS seller approved
Default ? Timing cover gasket set needed for 04 LQ9
I'm looking for a timing cover seal/ gasket set . They offer two different gaskets sets for my 04 LQ9 . One says it must be done with oil pan gasket and the other doesn't . I need this gasket set for doing a cam swap. So my ? Is do I need to try and replace the oil pan gasket or is that gasket set that says" needs to be done with oil pan gasket" overkill. The cam will be done in the truck.*
Old Feb 11, 2012 | 01:40 PM
Petey62782's Avatar
Bump bump
Old Feb 11, 2012 | 02:44 PM
midevil1's Avatar
Originally Posted by Petey62782
Bump bump
No need for the oil pan gasket when doing a cam swap. Just remove the two front oil pan bolts that thread into timing cover before removing it.
Old Feb 11, 2012 | 04:08 PM
mcfarlnd's Avatar
Un-Registered User
No need for oil pan gasket. You do however need a little rtv for the corners on the bottom of the front cover where it mates to the oil pan. I just re-used my front cover gasket...... Pretty sure I'm not the only one ether lol
Old Feb 11, 2012 | 04:52 PM
Atomic's Avatar
I have a gauge for that
Reuse all gaskets and dab some rtv at the bottom corners of the front cover.
Old Feb 11, 2012 | 07:54 PM
Petey62782's Avatar
As always great advice from the performance truck crew . Thanx again everybody
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
