Timing on 4.3
Timing on 4.3
How do u set the timing on the 4.3 without the round distributor. This one has 3 plugs on 1 side 3 on the other. You can't spin it any once it's in. If we go a tooth in either direction it won't start.
Right now it starts but sometimes takes a lil throttle.
SPAM HUNTER
I know the late 90s 350 only allowed for minimal timing changes, but a common issue was a worn distributor gear, it would cause a cam and crank coilation (i think thats what they called it) code. Might look there.
Changed the intake gasket.
If it was 180 it wouldn't start. It starts and drives but has a hard time starting. 1 tooth either way and it won't start.
Tried turning it by grabbing the cab and turning like u do with a gen1 but it won't budge. Do u pop the rotor off and turn it a bit?
PT's Slowest Truck
Good thread...I was going to ask the same question, doing intake gaskets on my 96 4.3 Blazer...what a PITA...lost a 16mm crowsfoot in the process and figured out that my torque wrenches need re-calibrating....hope I get it back together OK tomorrow...
So is there any procedure to setting the timing? Possible wire that has to be jumped?
