throwing the a/c belt
Old Sep 19, 2008 | 09:14 AM
sickREDsierra's Avatar
Default throwing the a/c belt
not sure why it has started this, but i have slung the a/c belt 2 times this week.. i guess it all this power ?
either way, i am not sure if the compressor had loosened from its mount, or the belt has stretched. i am gonna buy a new belt and try that ..
any one sure of where that compressor mounts up to the engine, or how many bolt it mounts with?
Old Sep 19, 2008 | 10:04 AM
built408's Avatar
compressor mounts with 4 bolts. Either your compressor is trying to lock up and its throwing the belt, or you tensioner might be week causing not enough belt tension.
Old Sep 19, 2008 | 10:18 AM
hirdlej's Avatar
Is your pulley tightened all the way? Do the edges of your belts look chewed up?
Old Sep 19, 2008 | 10:27 AM
thunder550's Avatar
High on diesel fumes
I had issues with this as well. I replaced the tensioner and now I don't have a problem anymore.
Old Sep 19, 2008 | 01:50 PM
budhayes3's Avatar
PT's Slowest Truck
Tensioner issues would be my first guess...
Old Sep 19, 2008 | 02:04 PM
silver-mod-o's Avatar
Hunt&Fisherator
I've been averaging about one a year... I'm probably due for a tensioner myself, likely to be your issue as well.
Old Sep 19, 2008 | 02:32 PM
i will check when i get off.. i think maybe the compressor might be loose?
whenever i pulled the tensioner down, the compressor moved about 1/2". i think it would sling the belt with that much movement..
the tensioner was pretty tight on there, the belt also looked decent.. i will have to take a look at it tonight though.
00loudchevy
Dec 3, 2015 05:54 PM
JordanH
Nov 6, 2015 07:42 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 27, 2015 10:16 PM
Hpinnovate
Sep 4, 2015 02:28 AM
