TBSS manifold on the way :}
Old Apr 22, 2011 | 04:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Thumbs up TBSS manifold on the way :}
Picked up one for a really good deal.. For now it will work just fine.. Considering the last few dyno charts I have seen have shown atleast a sold 15hp increase the entire rpm range, seems to be a good mod for cheap.. Hope it responds better to boost.. Plans so far are to possibly run after market rails on it, I am going to smooth the intake out, paint it black on the top, to finish it off with a clean look.. Might reroute some wiring also.. I had good intentions of going with a vic jr or pro flow, but for the cost it was going to be( new injectors, new fuel lines-fittings, new TB, Dr X link I could not justify it for 30 hp when this will get me close to them numbers for less then half. It would put me into the 900$ range.. So for now this should work well.. Hope it does..
Old Apr 22, 2011 | 05:30 PM
mhotrodscooter's Avatar
This is how mine looks.. I like to keep the stock look.
More AIR in has to be good for something..
Old Apr 22, 2011 | 05:33 PM
skolman91's Avatar
got any pictures of the L bracket you said you made to keep the stock cover?
Old Apr 22, 2011 | 05:40 PM
Baltimore Whore
I might be asking you a few questions here in there if i run into a snag. What did you get to extend the harness for the MAP sensor. Did you use the one you had or the newer one thagt comes in that intake?? Thanks, I will prob have more once it gets here.. Other then the TB, was it a breeze going on???
Old Apr 22, 2011 | 05:58 PM
My buddy's dad owns a/c shop and found it lying around.
I knocked the stock bolt out cover & weld it to bracket & grinded off head so I wouldnt be rubbing on map sensor. Wasn't sure on where the other hole needed to be so I notched it.
I think it sits a little higher the stock, but most of does it have a chip guys can't tell anyway.
Old Apr 22, 2011 | 06:03 PM
They got enough slack in stock harness for map sensor. Only Problem I had was my 42#injectors were to short for rails I had.
Old Apr 22, 2011 | 06:12 PM
Baltimore Whore
Did you use the rails that came with or the rails off the truck?? I plan to keep my truck injectors...
Old Apr 22, 2011 | 06:18 PM
Rails that came with intake. I had to cut taps off that held rails to intake.. Pretty simple I just had to think about it for awhile
Old Apr 22, 2011 | 06:20 PM
Baltimore Whore
Ok , I take it your running a 90MM tb with the link?? So other then them few things it went right on, correct??
Old Apr 22, 2011 | 06:35 PM
skolman91's Avatar
thanks for the pic, now i know what to do halfway. And i have my xlink in the same spot..
