swapping complete drivetrain pretty much
Old Jun 14, 2010 | 10:48 PM
Bumpers's Avatar
Default swapping complete drivetrain pretty much
This is gunna be my first swap by myself and I've never pulled motor/trans/transfercase out. If I remove the core support can I pull it all out intact? The only thing I'm gunna be reusing is the transfer case. I was just wondering if it will all come out together or do I need to pull the transfercase off first then pull the engine and trans together. I'm kinda nervous about doin this for the first time by myself. I've pulled a couple of engines out but never everything together.
Or can I take just the top bar out of the core supposrt and get it out?
Thanx fellas any tips advice anything will be greatly appreciated
Garrett
Old Jun 14, 2010 | 11:31 PM
Atomic's Avatar
I have a gauge for that
I would take the transfercase off the trans first. It would be a lot easier with 2 people: 1 to move the lift and the other to stabilize and tilt the engine.
Old Jun 14, 2010 | 11:46 PM
Bumpers's Avatar
Yea I will prolly be able to get alittle help but mostly I will prolly be on my own with this one I can always get my dad to operate the chrerry picker while I guide everything out
Old Jun 15, 2010 | 10:39 AM
dlt76028's Avatar
I pulled and installed a 5.3/4l60e together with no problem. I didn't take off the core support, so you should be able to easily with it off.
Old Jun 15, 2010 | 10:59 AM
fastrt's Avatar
11 Second Truck Club
I think I would remove the transfer case and trans if you have a lift. on the ground I would just do the case and pull out the engine and trans thru the top.
Old Jun 15, 2010 | 12:52 PM
Atomic's Avatar
How high is your hoist to be able to clear the rad support?
Old Jun 15, 2010 | 01:15 PM
dlt76028's Avatar
It's just a regular engine hoist from Harbor freight. All the engines swaps I've done, I've never removed the support or the radiator. You just have to get the chain in the right place and make it the right length. I will say that pulling the engine/trans together was easier then pulling just the engine to me.
Old Jun 15, 2010 | 01:29 PM
Atomic's Avatar
And you didnt take the oil pan off or anything? How much is your truck lowered? Im thinking maybe if I pull my tires and rotors off and set the frame down if I could avoid removing the front, since I really dont want to do that.
Old Jun 15, 2010 | 01:34 PM
dlt76028's Avatar
Nope didn't take nothing off. I pulled the engine /trans combo for a buddy of mine and his truck is stock 2wd height. Heres a pic from Krambos build.
Old Jun 15, 2010 | 01:39 PM
Bumpers's Avatar
thanx for the help fellas... im thinking since my truck is lifted im gunna take the top bar out of the core support to give me room just to slide it straight out
