Stock performance for 2001 Suburban 6.0l
Old Mar 26, 2015 | 05:35 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by Jordan927
Don't discount that EGR code. A plugged EGR passage or improperly functioning EGR system can cause all sorts of issues.
130 is a little low on compression...150-160 is considered good 200K
Have you done a wet compression check and a leak down check? Wet will tell you if the rings are getting bad and a leak down, dry then wet, will tell you if the valves are not sealing properly. Basically...if you get leakage when dry and none when wet your rings are bad...if you get leakage when dry and again when wet, your valves are not sealing. Also if the compression goes up significantly when wet you have bad rings.
Also look into plugged fuel filter, it can put out correct pressure, but restricted flow can cause this issue.
I would also clean the crap out of that engine, could be pretty carbon-ed up.
Seafoam or similar through the intake. Likely wont fix the issue...buy not a bad idea.
I have a friend with an 02 silverado 2500 with a 6.0L. It pulls very well, so there should be no issue.
Very good advice.
If the EGR is sticking in the open position it could chocking the engine. This could also be why you have a MAF sensor code as the o2 sensor readings indicate un-metered air is entering the engine.
These vehicles usually through a code when the cats are clogged.
I don't know anyone in your area.
If it were me, I would get another EGR valve and try it. Clear the codes and drive it to see what happens.
Old Mar 26, 2015 | 05:48 PM
mrvedit's Avatar
Thanks for the additional suggestions.
I'm sure my daughter will double-check that the mechanic performs those tasks.
Old Mar 26, 2015 | 06:41 PM
Jordan927's Avatar
Hate to say it...but if you want a good tech for a GM vehicle, you need to go to GM.
I know they're 100 bucks an hour...but sometimes you get what you pay for. Plus they have access to all TSB's and diagnostic equipment for those vehicles.
I've seen mechanics labor over an issue for days that the GM techs fixed in a forenoon. Not to say that other mechanics aren't highly skilled, its just that the guys at GM generally only have GM's to deal with, and they know the quirks.
Finding a really good mechanic is a PITA.
Old Mar 26, 2015 | 06:51 PM
1FastBrick's Avatar
Maybe in your area they are good but that's not always the case.
Good mechanics are always hard to find.
I have worked on and fixed several cars that have been to different shops including different dealers in the area and they still couldn't fix it.
Old Mar 26, 2015 | 07:55 PM
Jordan927's Avatar
Fair enough. We only have a few shops here. Word gets around if they suck.
Old Mar 27, 2015 | 04:02 PM
Cccasper00's Avatar
Registered User
Thanks for all your suggestions. It turns out that it was a clogged cat converter. The mechanic replaced it and now it runs like a champ! Not sure why the computer didn't pick that up but the MAF and EGR were fine so the converter was throwing those codes.
Old Mar 27, 2015 | 05:22 PM
Jordan927's Avatar
Excellent.
Sounds like you may have found a decent mechanic too.
ARC
57
Feb 21, 2022 10:54 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
cbhedrick
Jul 20, 2015 10:12 PM
oharajo
Jul 18, 2015 09:24 PM
