Stock intake manifolds...how good/bad are they?
Old Feb 14, 2006 | 03:45 PM
shandy294's Avatar
Default Stock intake manifolds...how good/bad are they?
Do they inevitably fail after several years...warping or whatever...or is just something you can't predict?
Old Feb 14, 2006 | 03:51 PM
zippy's Avatar
they are generally one of those things that don't fail unless they are made to fail.
Old Feb 14, 2006 | 06:38 PM
shandy294's Avatar
Thanks...anyone else? A friend has a 98 one ton with a leak...at about 100k miles.
I saw a V-6 that had a really bad one...steam coming out of the tail pipe and the radiator water level would drop when the engine was revved.
Old Feb 14, 2006 | 08:15 PM
zippy's Avatar
that's a whole different thing. the L30, L31, and L35 engines all commonly have intake gaskets that leak.
Old Feb 14, 2006 | 08:44 PM
shandy294's Avatar
OK,so it's more of a problem on the 6 bangers.
Old Feb 14, 2006 | 10:53 PM
hog's Avatar
hog
No its a problem on the 1996-2000 Oldbodystyle trucks with the 350 and 305 GEN 1-E V8s (L31/30) as well as the V6's.
tell your friend to go get the newer GM gaskets and only torque it to 11 lb/ft.
peace
Hog
Old Feb 15, 2006 | 01:37 AM
James B.'s Avatar
The only real problem with the Gen-III manifold is that air into the front impacts the rear of the plenum causing higher pressure to the #7 cylinder intake port. The extra air makes that cylinder burn lean under high-power applications (Boost). The resulting lean condition melts the piston. It has happened to dozens of people on this forum.
5.3Okasai
Mar 9, 2022 01:07 PM
TA63
Mar 29, 2016 04:38 PM
The_W
Oct 28, 2015 09:00 PM
Ketis
Jul 23, 2015 12:37 PM
4B11T
Jul 13, 2015 03:48 PM
