Steering Wheel Controls not illuminated anymore...??
Old Feb 17, 2008 | 10:34 PM
12 Second Club
Default Steering Wheel Controls not illuminated anymore...??
What is the fix, if anything, for this. It is both pads on the left hand side. On-Star/Prog., and Source, I believe. Same thing for rear temp control...anyone had to replace one of those due to no illumination??
Old Feb 17, 2008 | 10:37 PM
truckmann's Avatar
Common problem, replacing the steering wheel controls is the easiest solution. They just pry out and unplug. It will be cheaper to replace the bulb for the rear temp controller, but it is most likely a soldered in bulb so it is not necessarily easy.
Old Feb 17, 2008 | 10:57 PM
12 Second Club
awesome, thanks for the quick reply. I work for a salvage yard, so maybe i can locate a rear temp ctrl on our parts locater and just buy a used one to see if that will fix it.
Old Feb 18, 2008 | 09:47 AM
12 Second Club
don't have a PN by any chance do ya?
Old Feb 19, 2008 | 09:27 AM
truckmann's Avatar
https://www.performancetrucks.net/fo...d.php?t=376463
Look through or search that thread for part numbers. If you don't find it then ask in there. I used to have numbers for the steering wheel swithches and those numbers are in that thread, but I think a couple of the part numbers have changed since I bought new switches.
Here are the steering wheel swith numbers that I found.
VOL/SEEK 1999443
PROG/SOURCE 1999442
SELECT/PERSONALIZE 21997739
TRIP/FUEL 21997738
Old Feb 20, 2008 | 12:13 AM
chevyguy7802's Avatar
im gonna write the numbers down just incase mine give me problems!
Corvette454l88
Sep 1, 2016 01:24 AM
lxcoupe
Aug 22, 2015 08:23 AM
Ketis
Jul 23, 2015 12:37 PM
lxcoupe
Jul 8, 2015 05:49 AM
