Starter?
Old Sep 26, 2007 | 11:16 PM
nonnieselman's Avatar
The usual symptoms of the fpr occur after a hot soak, but it's worth checking...only takes a second to pop the vacuum line off. Have you happened to notice if the truck smokes when it starts up and idles rough...like it's running rich? Could be a fuel injector leaking also, or maybe even an IAC problem. You could also try cleaning the throttle body, it may be full of carbon and crud, creating issues with the IAC passages.
Ill check it.. .Im in Minnesota and my truck is in Mississippi..
Ill check that when i get home.
No smoke at Startup
Need to check the TB... its been awhile since i cleaned it.
Its not running rich... LC-1 says 14.7 at idle
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
bsn1989
Jul 16, 2015 08:20 AM
Mike_J
Apr 25, 2005 03:49 PM
slowprocess
Jan 5, 2005 01:13 AM
