SSS almost stolen!
Old Dec 13, 2012 | 04:20 PM
nonnieselman's Avatar
Hot lead is the best deterent.. it just comes with alot of paperwork..
Old Dec 13, 2012 | 04:22 PM
Originally Posted by JFOLM
Power disconnect to your starter
Starter is too easy to get to with some jumper cables..
Fuel cut, either ground or hot wire would be your best bet.. but not under the hood where you can pull the relay and put in a jumper wire from pins 30 to 87.
Old Dec 13, 2012 | 04:37 PM
ak2007r6's Avatar
Damn that sucks, lucky you got there when you did and not a split second later.
The toggle switch for the fuel pump sounds like a good way to start.
Old Dec 13, 2012 | 05:22 PM
zeake's Avatar
Toggle switch to fuel pump. Also add some things to your alarm. BUT GET THE ADDITIONS IN ANOTHER TOWN!!!!
also Concealed carry and a glock 40 or 1911 style 45
Old Dec 13, 2012 | 05:57 PM
03sierraslt's Avatar
Damn sorry to hear of that, good that you got to it before they took it though. My 1911 is my Alarm, and I don't DD my truck so I don't have to park it anywhere questionable. When I do drive mine to work its parked in a Secure Facility.
Old Dec 13, 2012 | 06:25 PM
Gadgetized's Avatar
Glad to hear you stopped it. Too many scumbags out there these days. I like the fuel pump cutoff idea, I might do that.
Old Dec 13, 2012 | 06:31 PM
ak2007r6's Avatar
Anyway to wire in the cut off to the alarm?? When you arm the alarm it cuts power to the fuel pump??
Old Dec 13, 2012 | 06:57 PM
Was the viper a quality install with everything hidden and loomed soldered and heat shrinked or was it a rats nest under the column with t-taps on all the wires. If it was the latter there was your problem. I did starter interrupt and a fuel pump cut that is tied into the alarm and hidden in a no one find it spot in a undisclosed location and it's soldered heat shrinked and 5 rolls of 3m tape to tape it all into the oe harness.
Old Dec 13, 2012 | 08:02 PM
DTHPROOF's Avatar
Good job on stopping the absconders!
Old Dec 13, 2012 | 08:25 PM
blown02408's Avatar
02 w/ lowest mileage 2800
I still like the bagged, body dropped, completely shaved, alarmed, fuel pump cut off, and quick release air line idea. Yes that was my last truck and I might be a bit paranoid, but it was never stolen or towed, lol.
