Squeakage...
Squeakage...
For quite some time now the front end of truck has been squeaking. At first I thought it just needed a lube job. That didn't fix it....Then I thought it was the break pads needing to be changed. Pads still have plenty left on them. It's weird, it squeaks when getting on the breaks lightly. It squeaks when I turn to the left, but not the right. I thought I had a little pebble or something stuck in between the pad and the rotor because of my dirt roads, so I flushed it out and it still didn't quit. Anyone had this problem before? Any suggestions to correction. Warranty is still up for another 8K so now's the time to figure it out I guess. Truck is an 04 Reg cab, 5.3, 2wd w/ disc all the way around if that helps. Any help appreciated guys cuz I'm outta' ideas at the moment.
PT's Slowest Truck
Could be something in the brake pad composition causing the squeak, or the anti-rattle shims on the backs of the pads aren't doing their job. You may also have a rusty lip on the rotors, my first two sets of factory rotors rusted away like crazy and would make a scraping noise even without the brakes applied.
Hmm, that may be it. I'll have to start takin' stuff off and examine them closer. Someone told me these new brakes just squeak and theres not much you can do about them. Thanks bud...
are you sure its coming from the brakes? these chevys have been having quite the issue lately about the e-brake cable passing through the hole through the frame under the drivers door...the line pushes against the metal on the frame and causes a creak/squeak noise from the drivers side...on slow accell and decel...just a thought have someone lay down next to the truck and listen for the problem...just my .02 it happened to me too
I don't know what the problem is, but my truck is doing the EXACT same thing....squeaks when I turn left and also when light on the brakes. Sounds like a damn bus stopping and is fn embarrassing...I am @90k miles and it just started a couple weeks ago.
Thickness on bads are ok but not ideal and hit it with a good amount of brake cleaner and no banana
Let me know if you find the problem.
Lol, I feel dumb, never would've thought this was causing it until I took it in and asked the service guy at the dealership.....and when he said it, I thought.."Wow, why didn't I think of that?" Got the front end aligned and solved everything, this one's for you 99Silv. Give that a try and see if that helps at all. Thanks for the insight Tyler, much appreciated.
