spare pulley wont let go
Old Sep 1, 2004 | 08:40 PM
Default spare pulley wont let go
the spare under my truck will not come out, I put the pole in and crank counter clockwise and the damn thing wont even move, it jsut clicks, I am sure I have it in their far enough, well AAA is coming out to see what they can do. If nothing I am calling the dealership and telling them to come pick it up and tow it where ever and put a new pulley on it and fix my tire. does anyone know what else might be wrong with the lowering system. I had this happen in a 96 chevy but I had a pair of bolt cutters and I jsut cut the wire, that is not an option right now. any help quickly would be appreciated. t hanks guys.
Old Sep 1, 2004 | 08:51 PM
chevymec's Avatar
You might have to slide your arm throught the rim(yeah I know its tight) and guide the tool in. There was a problem with this and you had to realign the spare holder . You might also have to pull the tube that runs from the spare holder to the bumper off to get the tool to line up.hope this helps
Old Sep 1, 2004 | 08:54 PM
the dealership can mess with that then. thanks, I feel totally stupid with soemthing being so easy and I can't do it.
Old Sep 1, 2004 | 09:00 PM
chevymec's Avatar
Hey if its under warranty let them do it. IT is an agrivating thing to do if the truck is on the ground.
Old Sep 1, 2004 | 09:37 PM
quicksilverado's Avatar
Make sure you are using the shaft with the right tip. I was gonna drop my spare to check the pressure in it and ended up having to put my hand thru the rim to remove the tube to see why the thing would not lower. Turns out I was using the wrong tip.
Old Sep 2, 2004 | 09:15 AM
I tried every tip, I even had AAA copme out and they had no flippin clue. I felt where the end went in but when you turn it it would jsut clicl like it's slipping. oh well just called the dealership and their going to come pick her up.
Old Sep 3, 2004 | 04:31 PM
I had the same problem, It ended up being the guide shaft fell out of place. I just put it back in place and worked fine. took me an hour to figure it out though.
Vortec350ss
Jan 12, 2016 10:36 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
