So I'm looking at buying a used 4.8L Silverado (few questions).
Old Aug 23, 2004 | 07:08 PM
GM Muscle's Avatar
10 Second Club
Default So I'm looking at buying a used 4.8L Silverado (few questions).
I've been keeping my eye out for a truck latly and saw one today that is exacly what I was looking for. Only problem is it has the 4.8 but, it's a 2000 with 55k and I can get it for $12,000. I have a few questions first since I'm not really a truck guru. What was the 4.8 rated at in 2000? What do they have for rear ends (10 bolt?) and is posi/aurburn standard with the 4WD? Also, how do these truck intakes like to flow fuel? It will have a nitrous set up for sure but it looks like I could run into some puddling issues with that big old intake. Here's a pic, I can pick it up tommorow if I want it. DO you guys think I should go get it or wait it out for a 5.3?
Andrew
Old Aug 23, 2004 | 07:26 PM
I'm not positive on the 2000 models but my 2001 is rated at 270hp. So you're in that area.
Old Aug 23, 2004 | 11:50 PM
nekkid_hill_billy's Avatar
well the intake is the same on the 4.8 and the 5.3 and you only gaining 20 ft lbs and 10 hp.........only difference in a 4.8 and 5.3 is crank and rods.........most 4x4s have 373 some open some are the eaton locker
Old Aug 23, 2004 | 11:51 PM
oh that is basically my truck except mine is a ls
Old Aug 24, 2004 | 12:30 AM
hyper's Avatar
if ur planning on doing alot of mods then just get it
Old Aug 24, 2004 | 12:46 AM
Mr. Sandog's Avatar
Nice truck, I say go for it. The 4.8 is a nice motor, almost as good as a 5.3.
Old Aug 24, 2004 | 07:17 AM
GM Muscle's Avatar
10 Second Club
Wow the HP power rating is actually better than I thought. More than likley it has an open rear end since the truck doesn't have many options. The locker code for my dads '03 is G80, it would be the same for this truck right? I'm going to go check it out again today.
Old Aug 24, 2004 | 09:04 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I just bought my truck a week and a half ago, and it has the 4.8L. I have no complaints about it at all. It's not nearly as fast as the T/A, but for a truck it still has plenty of get up and go....
I have the 3.73 posi in my truck, and it's an LS.
Old Aug 24, 2004 | 05:29 PM
GM Muscle's Avatar
10 Second Club
I bought the truck today. On the way home I discovered some issues. At WOT the truck threw a misfire code and showed like 5*of KR at 5,000rpm. Bank 2 LTFT was +16. It looks like they started to steam clean the passanger side of the motor and then stopped. Since Bank 1 looks totaly normal I think it's an injector problem and the dealer said that they would take care of it so I'm not to worried about it.
On the plus side of things I changed the plug/wires and it took less than 1/2 an hour. I used of it taking 4 hours wiht the Camaro.
Rafe19
Oct 18, 2016 12:27 AM
lycominghunter
Jul 29, 2015 04:24 PM
oharajo
Jul 18, 2015 09:24 PM
Moto733
Jul 12, 2015 10:25 PM
