So It Begins
Old Jun 25, 2009 | 08:37 PM
03 BLACKOUTSSS's Avatar
Default So It Begins
The heads / cam install...any tips or pointers that'll make things easier?
Anyone know the bolt size that I can use as a "handle" for the cam during removal / install?
When I drop the oil pan to loosen the bolt on the pickup tube, will the gasket be okay if I am careful? Any silicone needed upon tightening the pan?
I am going to try the lift and support the intake manifold method, as opposed to totally removing it, any tips?
Old Jun 26, 2009 | 12:44 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Use 2 or 3 of the longer water pump bolts as your cam handle.
Old Jun 26, 2009 | 01:29 AM
retraC's Avatar
Agreed! That was by far the easiest part about camming mine. As for the intake, I remember having enough room to probably slide a 2x4 under there, but removed it anyways; it's easy enough.
cheyenne383
Nov 13, 2015 09:24 AM
vmaxpro
Sep 28, 2015 11:10 AM
OHsixLS3
Sep 25, 2015 04:38 PM
GMCtrk
Jul 9, 2015 08:26 PM
