So It Begins
The heads / cam install...any tips or pointers that'll make things easier?
Anyone know the bolt size that I can use as a "handle" for the cam during removal / install?
When I drop the oil pan to loosen the bolt on the pickup tube, will the gasket be okay if I am careful? Any silicone needed upon tightening the pan?
I am going to try the lift and support the intake manifold method, as opposed to totally removing it, any tips?
Agreed! That was by far the easiest part about camming mine. As for the intake, I remember having enough room to probably slide a 2x4 under there, but removed it anyways; it's easy enough.
