Sierra Denali Tires Rubbing
Old May 7, 2013 | 11:52 AM
ZeroDiscipline's Avatar
Registered User
Default Sierra Denali Tires Rubbing
Tried searching, but could not find a definitive awnser about my set up. I currently am running 22" rims with 305/45R22 tires. Unfortunately, they seem to be rubbing when making any sharp turns. This is my first time dealing with this issue and I am relatively new to trucks. BTW, the tires were on the truck when I bought it. I could use help. What is the best soloution for this setup? Thank you!
Old May 7, 2013 | 12:30 PM
Hunter04's Avatar
Trade me for my 20x10 fuel hostages
Old May 7, 2013 | 02:06 PM
cammed00's Avatar
How long has it been doing that? Any drop on it?
Old May 7, 2013 | 03:24 PM
bdubb's Avatar
Tire model and brand? Although tires will call out the same size some brands and then even some models of tires will have different diameters. So some 305/44r22 tires may rub and others might not.
tire rack is a good place to look up specs on individual tire sizes.
Old May 13, 2013 | 08:37 AM
Registered User
They are Goodyear Fortera SL's. I read that 305/40/22 are the largest without issues. Is this a true statement?
Also, there is no drop on the truck. I'm going to take it to this spot down the road that deals with truck customizations. I'll see what they have to say.
Old May 13, 2013 | 10:22 AM
skolman91's Avatar
yes 305/40 or 32" tire is the biggest you can run stock height or a little drop and sometimes they still rub... a 305/45 is a 33" tire, you would need a slight lift to fit those properly imo..
Old May 13, 2013 | 02:06 PM
Registered User
Appreciate the info!
Old May 20, 2013 | 03:45 PM
dropped74's Avatar
This is the tire size I run dropped. I tried the 45 and if I only drove in a straight line they would have been perfect!
gnasty1521
35
Nov 19, 2015 11:42 PM
chacho44
Aug 3, 2015 04:07 PM
chacho44
14
Jul 25, 2015 01:47 PM
Denali man
Jul 19, 2015 03:52 PM
chacho44
Jul 16, 2015 09:03 AM
