Security light on/key won't turn
Old May 22, 2007 | 02:58 PM
shandy294's Avatar
Default Security light on/key won't turn
2000 Silverado; as stated,light on key won't turn. He disconnected the neg cable for about 5 minutes,reconnected and no change.
Any help is appreciaated.
Old May 22, 2007 | 03:10 PM
It's your pass-lock sensor, located in your ignition switch case. The GM part # is 88965342.
Old May 22, 2007 | 03:55 PM
shandy294's Avatar
Thanks
Old May 22, 2007 | 04:10 PM
Nick™'s Avatar
the key won't turn in the cylinder??? if that's the case it's not the pass lock
try grabbing the steering wheel and turning it back and forth while trying to turn the key
Old May 22, 2007 | 05:15 PM
shandy294's Avatar
tried that
Old May 23, 2007 | 07:45 AM
shandy294's Avatar
He has a heavy key ring;maybe that,over a 7 year period,caused a mechanical problem in the lock cylinder.
Anyone else want to chime-in.
Old May 23, 2007 | 07:53 AM
Yeah and the lock cylinder turns inside the Ignition Case wich has the pass lock sensor in it. It's what I reccomended he change. If the Ignition Case is bad, then key cylinder will not turn.
Old May 23, 2007 | 09:42 AM
2k4tahoe's Avatar
is your key really worn down?
Old May 23, 2007 | 10:46 AM
shandy294's Avatar
He tried his other key,too. A locksmith is coming who does auto stuff.
Thanks for the replies.
Torque Wrench: He can't identify the pass lock. The key does not have a chip in it.
Old May 23, 2007 | 12:06 PM
The key won't have a chip in it. The passlock sensor works off the key & cylinder position.
Trust me....
