Rim fitment 17x9 +12mm w/ 5.5" bs
Old Mar 22, 2016 | 10:41 AM
Hvyhitr's Avatar
Default Rim fitment 17x9 +12mm w/ 5.5" bs
Will this fit a 05 rcsb? Tire size suggestions?
Old Mar 22, 2016 | 11:43 AM
Vortec350ss's Avatar
It will fit yes. What is your suspension set up?
Stock height you could probably fit a 285/70 on that wheel if thats the look you are going for. If you are lower I would go 275/60 nitto 420s
Old Mar 22, 2016 | 12:07 PM
Hvyhitr's Avatar
Its at stock height now. Thinking of doing the djm 4/6 kit.
Old Mar 22, 2016 | 12:41 PM
then I would do the nitto tires. They are a tad shorter than stock with a slightly wider footprint. They will look good and should provide decent grip/
Old Mar 23, 2016 | 03:28 AM
Suburbazine's Avatar
If you're going the drop route, I'm quite happy with my General Grabber UHPs in 275/55R17. Much better handling than the Nitto 420s and superior traction as well (the 420s is too slippery in the rain for my liking).
The downside of the Grabber is the directional tread (which gives the traction boost), which prevents rotating the tires from one side to the other.
LSOHOLIC
Mar 19, 2016 02:27 PM
Tanner Peterson
Mar 16, 2016 08:09 PM
TwiZtedZ71
Mar 15, 2016 06:41 PM
SlicksNchicks
Mar 6, 2016 06:14 PM
lxcoupe
Mar 2, 2016 03:20 PM
