Replacing the BCM on '02 Silverado
Old Oct 23, 2010 | 03:58 PM
lady3bglover's Avatar
Default Replacing the BCM on '02 Silverado
Hey guys I've been looking for a thread on how to replace the BCM (Body Control Module) for my truck.
If you have any input, I'd appreciate it.
Thanks.. Lisa
Old Oct 23, 2010 | 06:50 PM
budhayes3's Avatar
PT's Slowest Truck
I know that it's located on the driver's side, straight down underneath the steering column. I was able to access mine without removing the lower panel, but to replace it, I'd assume that removing that panel would make it a lot easier. Why are you replacing it Lisa?
Old Oct 24, 2010 | 01:25 PM
fastnblu's Avatar
I wondered the same thing, why is does it need replacing?
Old Oct 25, 2010 | 12:28 PM
dlstewart01's Avatar
Correct me if I'm wrong but replacing it would involve the dealer. I believe it is tied to the VIN.
Old Oct 25, 2010 | 07:55 PM
none of the lights are working ie...fog lights or when you turn on or off the alarm no lights flash....
Old Oct 26, 2010 | 03:10 AM
99LsSilverado's Avatar
If you are going with a new BCM from a dealer I believe that they program the vin into the new one for you. If you are going with a used BCM then you have to get it to learn the current theft deterant code with a process of a relearn which is to turn the key to the run position and the Securety light will flash and let go for 10min, turn the key off for 5sec and repeat. In all that process needs to be done three times for the BCM to learn the code and the truck should start and run.
Old Oct 26, 2010 | 04:14 PM
You have a ground problem some where in the system...
Old Jan 15, 2011 | 06:27 PM
gcsd3742's Avatar
nope it wasnt the BCM....She did have a bad ground as a matter of fact there were burnt wires.....$400 later the dealer fixed that
5.3Caprice
Nov 7, 2015 08:56 PM
Ketis
Jul 23, 2015 12:37 PM
mrgrim
Jul 8, 2015 08:12 AM
Nimoryan
Jul 5, 2015 03:50 PM
