quick question about sea foam
ok, im going to be puttin that stuff in my truck, i dont want to do it through the gas tank, i want to put it in through the pvc valve.... where is the damn thing ???
driver's side of motor, back in the back near end of block you will see a nice size vaccum line back there running to under the plastic enginer cover. Remove it from the back of the motor and the PCV is in there.,
Originally Posted by UBLUZIN03
What exactly does sea foam do?
also cleans your top end if you get it in the brake booster line, cleans the injectors through the gas tank and cleans the lower end if you put it in your oil. good **** IMO.
