Quick question about ext cabs
Old Mar 23, 2013 | 07:18 AM
Rule69's Avatar
Default Quick question about ext cabs
Whats the differences between the 1500 and 2500 Silverados? I have the 2500 and want to get a cab fwd so I can do mods to both the cab and engine with minimal down time to my DD.
Thanks for your time,
Tom
Old Mar 23, 2013 | 10:25 PM
Chevygearhead84's Avatar
The differences in 1500 and 2500 are in suspension and drive train. Heavier duty springs, axles ext. Might be a little differense in frame to make it stronger. Body and int will be the same.
Old Mar 24, 2013 | 07:10 AM
Rule69's Avatar
Ok thanks. Because I want to build a motor and other things and want to have very little changing when I transfer it to my DD.
Thanks for your response Chevy.
Old Mar 24, 2013 | 07:55 AM
TIM Z's Avatar
11 sec. Truck Mod
The 2500 has a taller frame , 2" .
Has a 14 bolt rear end
Larger rear leaf springs
Front control arms are different
Larger front Differential
Front bumper cap is larger than 1500 due to taller frame
8 lug pattern vs 6 lug
All sheet metal /cab /beds are interchangeable , no diff.
Hope this helps
Old Mar 25, 2013 | 07:46 AM
Rule69's Avatar
If I build a turbo setup on a 1500 it would be a direct change over if I build it with the same motor that I'm going to put in my 2500. The reason I'm asking is that I can find wreckred 1500s a dime a dozen but no 2500s
Old Mar 26, 2013 | 12:32 AM
Frame is also wider a decent bit as well you sure the cab mounts are in the same spot. The easiest thing to do is call a salvage yard and see if their hollander book shows the 2500 cab to fit a 1500. I'm with time believe they are the same but frame width may be a killer maybe not but worth looking into.
Old Mar 26, 2013 | 05:05 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Nope the cabs are the exact same, the frames might be a bit wider but they just change the mounts of the frame to accomodate the cabs
GXPJAY
Feb 13, 2022 08:15 AM
X_Racing1
21
Mar 30, 2016 02:37 PM
mhorn0817
Mar 6, 2016 08:00 PM
Three6GMC
Aug 28, 2015 07:56 AM
tito green
Aug 14, 2015 06:01 PM
