Question about Diff Fluid Change...
Old Feb 21, 2007 | 11:48 AM
Carlos's Avatar
Default Question about Diff Fluid Change...
I am going to be changing my Diff fluid for the first time and the manual i have says to remove the drain plug on the bottom of the differential, only i don't have a plug at the bottom of my diff. They have a pic of the diff in the manual and where its SUPPOSED to be, but mine is completely blocked off. I have the correct year and model but it doesn't look the same, do i just need to unbolt the diff cover, clean gasket surfaces, install new gasket, bolt it back on and fill or am i missing something in there?
Old Feb 21, 2007 | 12:45 PM
truckmann's Avatar
Yep just unbolt the cover make a mess, clean it up, put it back together and refill.
Old Feb 21, 2007 | 12:48 PM
Carlos's Avatar
what do i need to use to clean off the gasket surface, will a regular ol putty knife do?
Old Feb 21, 2007 | 12:54 PM
truckmann's Avatar
Putty knife should do ok. Maybe a razor blade if stuff's really stuck on there. Just try not to gouge the gasket mounting surface. I also like to use a mild abrasive pad with my die grinder to clean the mounting surface.
BCraven1018
37
Dec 20, 2016 11:46 AM
Turk55
Sep 11, 2015 11:52 AM
vmaxpro
Aug 8, 2015 10:49 PM
USMCvet0311
Aug 1, 2015 07:45 AM
walledition
Jul 29, 2015 08:54 PM
