Power steering noise only turning left??????
Old 10-19-2011, 10:54 AM
Default Power steering noise only turning left??????
My 05' Yukon is having an issue with the power steering making noises, like a slight squeel. But its only when turning left. Right turns are fine. I though maybe its the belt, so I cleaned the pulleys and used some belt dressing. No change. Then I added a bottle of Lucas power steering stuff to stop the noise. Still no change. There are no visible leaks and everything is working fine. The hydroboost is fine as well.
Any ideas, this noise is driving me crazy!!!
Old 10-19-2011, 01:24 PM
PT's Slowest Truck
budhayes3's Avatar
There may be an issue with the spool valve in the gear box...do you notice that it's harder to turn left also, or are you just getting the noise? Is there anything rubbing while it's turned?
Old 10-19-2011, 02:28 PM
Turns the same both ways, nice and smooth. I'm just getting the noise. No rubbing, I can have the wheels straight in park and just start to turn left, or pull the wheel slightly left and it makes the noise.
Old 10-19-2011, 06:05 PM
PT's Slowest Truck
budhayes3's Avatar
My truck has always made a slight "whistle" when I made a sharp parking lot type of turn...I think that it's probably the pressure releave(sp?) valve or something. I never paid enough attention to it to see if it only happens in one direction. I told the dealer about it when it was still under warranty, and, as what often happens, they couldn't verify the condition.
Old 10-27-2011, 05:36 AM
03 BLACKOUTSSS's Avatar
99% sure that the PS pump is on its way out. not too many reasons for it to squeal. grab another one, I replaced mine with an aftermarket, no squeal.
Old 10-27-2011, 07:19 AM
oldred95's Avatar
100% sure there is a bulletin about this exact problem. Depending on the type of steering gear its either install a small orficed fitting on the pressure line at the gear box or replace it with a box with a redesigned spool valve in it.
03regcab sierra
20
08-03-2015 12:11 AM
Ketis
07-23-2015 12:37 PM
Denali man
07-19-2015 03:52 PM
1320Chicken
07-14-2015 10:58 PM
lxcoupe
07-08-2015 05:49 AM
Quick Reply: Power steering noise only turning left??????
