Popping noise
Old Sep 5, 2014 | 12:11 PM
BUTTERB30's Avatar
Default Popping noise
NEED HELP i have a noise that just started and its only when im reving the motor, sounds like firecrackers going off in side of engine. so i had my sister rev it up while i looked to see if any sparks were visibly (broken wires) and none but i did notice that it sounded like the pop was comming from inside the head on the passenger side... any ideas?? and plugs and wires have been changed and i noticed my manifold bolts were loose so i retightend them but still same noise
Old Sep 5, 2014 | 06:40 PM
Mark Johnson's Avatar
When revving the engine. Only when freewheeling or also under load? Could be either timing(lousy gas) or a vacuum leak.......
Old Sep 6, 2014 | 05:03 PM
Suburbazine's Avatar
Preignition caused by bad gas, electronic malfunction or valves not closing properly.
Old Sep 7, 2014 | 11:05 AM
BUTTERB30's Avatar
i can just sit in the driveway and it runs fine under idle but when i rev just sitting still it starts popping say around 3000 rpm and up and i did have an exhaust leak but i just got done fixing all that hoping it would fix it but no luck so im guessing i need to pull the valve covers????
Old Sep 7, 2014 | 12:38 PM
Run a tank of premium gas and see what happens. BTW- what year of vehicle are we talking about?
Old Sep 7, 2014 | 07:56 PM
BUTTERB30's Avatar
ITS an 05 gmc sierra with the 4.8 and also ive only ran 93 since i bought the truck when it had 40,000 now it has 84,000
Old Sep 11, 2014 | 07:43 PM
been meaning to get back with ya, do ya have something like HP tuners with which you can do a road scan and look at the timing table..........
Old Sep 11, 2014 | 08:46 PM
BUTTERB30's Avatar
i do have hp tuners but i ended up driving out the gas i had in the truck and refilled and and whaaa laa no more popping so im guessing for now it was bad gas but i do have another question and this might be wrong forum. whats a good clutch to have in this vehicle with my 5 speed manual cause mine is slipping and what gears are good for the rear end THANKS
Old Sep 12, 2014 | 08:55 AM
Bravo on the gas. Can't help ya with the clutch- I'm Mr Slushie. the might be able to tell ya something over in Drivetrain & Suspension............
Last edited by Mark Johnson; Sep 12, 2014 at 09:27 AM. Reason: Gammatical and Syntax errors
00loudchevy
Dec 3, 2015 05:54 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
