plug wires ?
Old Aug 29, 2008 | 07:05 AM
Exclamation plug wires ?
is there some damn special trick to getting these off on a 01 5.3L
thanks
Old Aug 29, 2008 | 07:20 AM
SnakeOiler's Avatar
twist then pull.
Old Aug 29, 2008 | 07:48 AM
JakeBrakeIH's Avatar
Originally Posted by SnakeOiler
twist then pull.
yeah there are a pain to get off...just keep workin on em...and make sure when u re-install them to push really hard until you hear a click
Old Aug 29, 2008 | 08:02 AM
viciousknid's Avatar
Where's the Beef?
I get behind them with a flat head and pry while pulling. gives a lil extra leverage.
Old Aug 29, 2008 | 08:27 AM
it makes for a pain in the ***, cause they have these plastic aluminum sleeves that leave just enough to get 1 finger on the end of the wire
Old Aug 29, 2008 | 09:20 AM
nonnieselman's Avatar
put some dielectric grease on the new ones... helps remove them later...
Old Aug 29, 2008 | 12:01 PM
gtosilverado's Avatar
get some pliers... grab on to the metal sleeve, but not so hard that ur puttin too much pressure on the rubber part., and then pull.... works for me.
Old Aug 30, 2008 | 12:53 AM
budhayes3's Avatar
PT's Slowest Truck
It's all about the twist...
Old Aug 30, 2008 | 02:28 AM
454SuperSport's Avatar
yep, the twist breaks the seal then they should wiggle off.
Old Aug 30, 2008 | 03:22 AM
Thumbs up
thanks guys the screw driver idea did it for me
