please help! truck will not start 04 chevy 4.3L v6
Old Jul 8, 2008 | 10:30 PM
STS95T/A's Avatar
Default please help! truck will not start 04 chevy 4.3L v6
truck started to run rough on the way to work today i thought it was bad gas. i stopped and filled it up with premium and added a bottle of fuel injector cleaner. truck started to feel like it was running better, then i let it sit for a few hours and now it will not start.
i pulled off the intake when the accessories where on and depressed the fuel pressure release and no fuel came out. it still turns over and smells like gas comming out of the tail pipes but no fire
i'm thinking either the filter or the pump, what kills me is the truck only has 40k miles
any suggestions?
thanks
robbie
Old Jul 8, 2008 | 10:35 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
When you key on can you hear the pump pressurizing the lines?
Old Jul 8, 2008 | 10:49 PM
2005 Silverado's Avatar
SPAM HUNTER
What year truck? Is the battery charging? Or holding a charge? (low voltage can cause alot of issues)
Dustin
Old Jul 9, 2008 | 07:04 AM
skeet's Avatar
theres a electronic coil on the left hand side when looking at the engine, its black and i think it has 2 wires that go to it... if you have fuel pressure and all else is fine change that coil. cant remember the exact name of it, but i went through this same scenerio before i did a engine sap..
on yeah this was on a 99-02 4.3 silverado
Old Jul 9, 2008 | 11:06 PM
sixltrbtr's Avatar
Pull your distributer cap and look for lots of white corrosion. May even be some white looking slime. Those trucks have a problem with moisture getting into the cap. If it's there change the cap and rotor. I've seen several of these 4.3's with this problem. Low milage and wont start.
Old Jul 14, 2008 | 07:54 PM
sixltrbtr's Avatar
Ever get that truck fixed?
ARC
57
Feb 21, 2022 10:54 AM
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
