PI Customer Service: A+
Old May 12, 2005 | 03:38 PM
Weedo's Avatar
Default PI Customer Service: A+
My PI Vig 3000 that I had installed didn't brake stall nearly as high as I had hoped. It would see around 2300rpm at 4psi of boost. Long story short, PI is going to next-day-air another Converter with a few hundred rpm higher stall. A+ on the Customer Service!
On a side note, I learned more about things like the difference between a PI with a turbo stator and, say, a Trailblazer converter. If they both "brake-stall" at 2500rpm, the PI is going to "flash-stall" much higher and be more efficient. There were some other fine details as well. This isn't to bash on the TBC either, just why one costs about $700 more, uhhhgg....
Old May 12, 2005 | 06:27 PM
1Blown04's Avatar
Cool, hope it works out well for you. Any plans on taking it to the track? I am curious what it will do.
Old May 12, 2005 | 06:51 PM
KySilverado's Avatar
Good to hear. I'm on the fence leaning toward a PI Vigilante 2600-2800 for my ride. Would love you to come back and say you picked up a half second or more E/T. I'd be on the phone to PI.
Old May 12, 2005 | 08:24 PM
Black Blown 02's Avatar
Cool! What else did you learn?
Old May 15, 2005 | 09:58 AM
Kano's Avatar
thats great CS
Weedo PM sent
Old May 16, 2005 | 10:45 AM
Weedo's Avatar
I'll probably pick up a second, hopefully more, but I'm doing more than just the stall. My old trans was slipping, bad, so I put in a new trans which should give me a few tenths alone. I'm also going to up the boost a bit or the timing or both depending on how the tune goes. Not only that, I was at 2psi of boost brake stall with the gas mashed and I should be around 6-7psi brake stalling now. That's the difference of about 80 more HP off launch!
thompson
Dec 27, 2017 06:48 AM
turbo6c3
Oct 5, 2015 06:11 PM
Velocity1
Oct 2, 2015 08:01 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 04:22 PM
