Parish Watch out
Old May 10, 2005 | 12:26 AM
  #51
Originally Posted by GirlsDoItRight
ummm Throw it away ay? damnit.. i should have thought of that sonner... of course Carbon fiberglass and than take off the doors, grill, head lights, a/c ****, the truck bed(bc who the hell needs that?) and than a carbon fiber block... (sarcasm)
You don't need a carbon fiber chassis, just an F-18 jet engine.
Old May 10, 2005 | 12:27 AM
  #52
Weight loss would be easy wey. Just make a cheap hood, fenders and bumper out of fiberglass, super easy, and you'll lose a couple hundred there.
Old May 10, 2005 | 08:13 AM
  #53
01Blackerado's Avatar
Jim, dont sell yourself short now... You have to remember that while he has a lighter body, he is also switching his setup to a turbo... he may gain a little more power than he has now but, with you being heavier....you put more load directly on that turbo and I think you know what I'm getting at. Up that boost because where his chokes out you should be able to gain enough HP and Trq over him to either counter the effect of the weight reduction and win or enough to at least keep him in the seat of his pants trying to stay away from you. Your turbo is going to reach its full rpm much quicker under load and continue to hold it longer as well
Old May 10, 2005 | 06:31 PM
  #54
parish8's Avatar
single digit dreamer
, what did you just say?
Old May 10, 2005 | 09:49 PM
  #55
zippy's Avatar
i'm lost on what he was trying to say.
i am interested in comparing yours and his dyno sheets though.
Old May 11, 2005 | 01:30 AM
  #56
1FUNZ71's Avatar
14 Second Truck Club
No just a carbon bed. That will put you there.
Old May 11, 2005 | 07:37 AM
  #57
Basically saying that the heavier the vehicle is the more load there is on the engine. The more load on the engine, the more exhuast it kicks out per rpm. The more exhaust it kicks out sooner (lower rpm) the sooner you spool...When your up top in the rpm band the engine doesnt have to work nearly as hard to keep or get you moving faster, unless there is resistance, then the vehicle slows down or doesnt really gain much more mph. Since they are both going to still be farely close in weight and I'm assuming JLP's new turbo will be smaller than P's, I was saying since P has more load on the motor itself in turn putting out more exhaust per rpm he should be able to boost his turbo a little bit higher than JLP's. So while JLP has the power and weight reduc. Jim could have MORE power and hopefully have a better power to weight ratio, with less traction problems!
Old May 11, 2005 | 08:28 AM
  #58
ap2002's Avatar
huh????
just kidding man!!!
Old May 11, 2005 | 08:35 AM
  #59
jksz71's Avatar
Parish, as soon as I read about Drag Week all I could think of was a certain blue truck that would make everyone a little nervous. You'd be the perfect sleeper for that set up no doubt.
Old May 11, 2005 | 04:53 PM
  #60
parish8's Avatar
jlp will be 1000+lb's less weight than me and have huge slicks, once he gets a turbo on there i wont have a chance. it's ok, i need to compete with the guys that have streetable trucks.
