Out of Storage motor
Old Dec 17, 2010 | 08:30 PM
99LsSilverado's Avatar
Default Out of Storage motor
I have a question about taking a motor out of storage. I will be needing to swap motors because of a rod knock in this one. But the question is what should be done to help prevent damage to the engine? I had backed off the rocker bolts to close the valves before storage and taped off the intake and exhaust ports. I also made sure that all coolant and oil passages were taped off too. Any advice on restarting the engine would be great
Old Dec 18, 2010 | 01:32 AM
Mrgoodwrench3's Avatar
New oil, and I would pull off the valve covers and pour oil all over the rocker arms and down the push rods. After the initial start up I would drain and fill the oil again.
Old Dec 18, 2010 | 07:46 PM
Thanks for the answer I was not too sure for starting a used motor for the first time after it has sat for 2 years.
Old Dec 18, 2010 | 08:08 PM
iamkeniff's Avatar
pull the fuel pump fuse and spin it over about 5-10 sec a few different times that way oil will run through the motor imo. id then put the fuse back and spin it over. if it cranks on the first try id let it run 15sec or so and kill it then crank it again. id let it idle till its almost to operating temp then ease it out the driveway and see how it acts.
Old Dec 19, 2010 | 08:33 PM
zero2sixT's Avatar
Im not sure, but I think the engine he wants to swap to is on a stand?
If its in a truck, I say go with above advice. If its on a stand, I'd spin the crank a few times and feel how smooth it turns. If the crank turns fairly easily, I'd swap to it. My LQ9 sat for months, possibly over a year. It was stored indoors, but not near as well as your engine. I swapped the cam out, and we dropped in the engine. Fired up, and 500+ miles later runs good w/ no mechanical issues whatsoever.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
