opinions please. built l92 procharged silverado vs built diesel.
Old Nov 9, 2012 | 05:35 PM
MNY5HOT's Avatar
Default opinions please. built l92 procharged silverado vs built diesel.
What do you guys think will happen with this new setup I'm putting together vs a built diesel on the street
2007.5 Silverado ext. Cab 4x4 lifted 9" on 37" tires on 22" wheels. Most built diesels where I live are lifted.
Kooks longtubes
Fully forged l92
Diamond pistons
Supercharger cam
AFR heads
Head studs
Fast lsxrt intake
Procharger d1sc @ 13lbs
Alky control methanol injection
Built 4l60e
3200 triple disc converter
4:10 gears
True Trac
Old Nov 9, 2012 | 06:03 PM
amanuel's Avatar
How much power you making? My slightly uneducated guess says over 600 but I'll be conservative and guess ~600. Depending on the extent of the modding on the diesel you could take him. However I believe they do take to mods very well.
Soooo much torque
Old Nov 9, 2012 | 06:39 PM
ak2007r6's Avatar
Your build is very similar to mine! What all is done to the diesel? your truck should be making some very impressive power but the lift and rims/tires is gong to hurt you some. Curious how much that 4l60 is hating life with all that power and lift LOL!
Old Nov 9, 2012 | 07:21 PM
darnie's Avatar
ill say this... my roomie has a 2005 dodge cummins 5.9 4 door long bed on 37's 6-speed. his mods: bored 30 over, new pistons, new cam- 70hp. studded heads, new crank, 60hp injectors, twin cp3 fuel pumps, 5in turbo back exhaust, Intake, and a smartie programmer. with the tuner on level 3- 90 hp. i can still beat it my mods are in my signature. he is running a stock turbo " hes building it for twins... 97 psi " but neways he should be around 550-600 hp and 1100 TQ at the moment. so id say u could do pretty dam good.
Old Nov 9, 2012 | 08:48 PM
2doorfury's Avatar
I had a duramax dually ext. Cab 4x4, weight was probably around 7500lbs. Had efi live, water/meth and bolt ons. I was making 586rwhp. it ran 13.5's. But it all Depends on what platform he has and mods. A diesel that is running mid 10's rarely is capable of street driving. And has Built everything. Id say ur setup is capable of high 11's. And in a diesel, 11's consist of lots of mods and money.
Old Nov 10, 2012 | 06:33 AM
DTHPROOF's Avatar
^^^Exactly
Old Nov 10, 2012 | 03:13 PM
GREENSIERRA's Avatar
I raced a 550hp diesel with stock height and tires with my setup and I waxed him till about a 100 but after that he was coming up strong.
surprised the **** out of him that a little 5.3 ran that strong.
Old Nov 10, 2012 | 07:28 PM
abey15's Avatar
My buddy has an 07 lbz with a lift pump and an efi tune and runs 13.4s all day on 20s. The tranny has a transgo jr. Shift kit with a stock converter that's loose as hell and the four by launch is rediculous!!!
For a full weight crew cab truck its extremely fast!
Old Nov 17, 2012 | 02:21 PM
MNY5HOT's Avatar
ill toss a 100shot nitrous express plate kit on it for insurance
Old Nov 17, 2012 | 04:24 PM
Whitecrewcab's Avatar
There is a common rail Dodge 2500 CC 4wd that runs 11.50's here in El Paso and that's at 4000' elevation. He daily drives it too. We tried to talk a 90k dollar GTR into running him last night but the guy was scared lol. I would be cautious running a modified diesel and try to find out what all is done.
