oil pressure issue need help asap
Old Dec 8, 2008 | 06:41 PM
gmc6.0's Avatar
Default oil pressure issue need help asap
i final got my truck back from the dyno shop had it for about a week and now i notice that my oil pressure gauge reads around 20 but dosent pass 40 psi at wot whats wrong i need help...asap
Old Dec 8, 2008 | 07:02 PM
GMCtrk's Avatar
Did they install cam? If so it's possible that the O ring got pinched, common problem. Otherwise your pump could be dying. I wouldn't run the engine myself until I got this taken care of...don't want to lose a motor over no oil pressure
Old Dec 8, 2008 | 07:10 PM
gmc6.0's Avatar
yeah they install a cam wheres the o-ring im new at this sorry for sounding stupid
Old Dec 26, 2008 | 02:06 AM
i have the same problem, cam installed 2 summers ago tho. at wot mine is around 60. it use to shoot right up to 80 though.
Old Dec 26, 2008 | 09:39 AM
budhayes3's Avatar
PT's Slowest Truck
The o-ring for the oil pump pick up tube...if they had to remove or replace the oil pump.
Old Dec 26, 2008 | 09:55 AM
OnyxSilveradoSS's Avatar
or if they banged a cam bearing...and spun it, then you will lose pressure. check the drain plug. if it did happen you want to get the cam out, it might be savable????
Noah Burns
Sep 7, 2015 05:50 PM
superchomper2003
Aug 26, 2015 09:39 AM
Chiphead
Aug 18, 2015 06:53 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
