Oil press. problems Help
Old Nov 9, 2007 | 11:02 PM
jow02327's Avatar
Default Oil press. problems Help
ok guys got the new TSP shortblock in and everything else. did the two break in cycles like TSP recomends. At first start showd 40+psi and through both breakin cycles. After changing the oil and starting it to check for pressure, 40psi again, we shut it down for the night. today started right up but didnt show any pressure, weve checked everything we can think of except for pulling the front end apart. any help will be greatly appreciated thanks in advance
Old Nov 11, 2007 | 08:19 AM
Put a manual oil pressure gauge on it. If you have pressure, then it is the sensor at the back of the block. If you don't have pressure, start tearing it down. Make sure the o-ring is in good. Did you get an LS6 oil pump? Last things to think about would be bearings. I wouldn't think it would be that, but you never know.
Texas5.3_1251
Mar 5, 2016 08:10 PM
600 horses
Sep 10, 2015 11:01 AM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
