aeroforce intercepter
Old Nov 10, 2007 | 06:45 PM
regency's Avatar
Default aeroforce intercepter
is this the right gauge to get i want it to a A/F ratio also does this one have it
http://www.stylintrucks.com/parts.as...&partid=512852
Old Nov 10, 2007 | 07:17 PM
quicksilverado's Avatar
It will not read a/f ratio. You need a wideband for a/f if you want it to be accurate
Old Nov 10, 2007 | 07:21 PM
regency's Avatar
i thought i have seen ppl with the intercepter in a A/F scan
Old Nov 10, 2007 | 08:14 PM
kbracing96's Avatar
You can display A/F with it using one of the analog inputs, but you have to have a wide band O2 to input the data. I have mine setup that way with a Tech Edge WB.
Old Nov 10, 2007 | 08:57 PM
regency's Avatar
ok so theres an aux input on the back of it???? and would this be a good way to read it or just get a seperate gauge
Old Nov 10, 2007 | 09:39 PM
danv's Avatar
The gage has two analog inputs, as well as being able to look at many other functions via the obdII port.
Pretty cool gage, I've got one along with boost and fuel pressure gages, Usually have it set to read trans temp and IAT. although last week mine crashed, I guess I have to send it in for the latest update
My plan is to get a wideband and use the Aeroforce to display the A/F and trans temp at the same time..
d
I looked at your link and I think that is of the older model, the new one has shift lights and is supposed to be able to show HP, 1/4 mile times, 0-60' time etc as well...
d
Old Nov 10, 2007 | 11:21 PM
regency's Avatar
yea i saw that one but i dont want all that
Old Nov 11, 2007 | 01:47 PM
Red04Silverado's Avatar
I believe all of them are like that. When I order mine over a year ago, I was sent the new one.
Bluchevypick
Aug 18, 2015 09:11 AM
Gotcha
Mar 28, 2008 11:58 AM
sprayed99
Jan 7, 2008 06:36 AM
moregrip
Jul 16, 2007 09:58 AM
m7 rocket
Oct 20, 2006 12:34 PM
