Oil Level Sensor???
Old Feb 10, 2005 | 03:32 PM
lifted99's Avatar
Default Oil Level Sensor???
I was changing my oil today, and while the oil was draining I got in the truck and turned the key to run to see the milage for my log. Obviously the oil was low (draining). Then I finished everything, filter and 6 qts of oil, but now when I start my truck, it says "Check Oil Level". On the dipstick it is right in the middle of the operating range. Nothing leaking, and I put the right amount in. Question: Could it be that the oil level sensor read it was low when I was checking the milage, and stored a code that must be deleted? I don't want to drive it until I get this fixed, although the ~1 mile did drive it, it ran just like normal.
Old Feb 10, 2005 | 03:43 PM
shandy294's Avatar
If I had to hazard a guess,I'd say it stored a low oil level code that needs to be reset somehow. The only one I know how to reset is the 'change engine oil' message with the five cycles of the gas pedal. Someone will chime-in who knows.
Old Feb 10, 2005 | 04:35 PM
SnakeOiler's Avatar
It won't hurt you to drive it. It's got enought oil in it ( you put it there yourself).
Disconnect the battery and hook it back up - see if that helps you out any.
Old Feb 10, 2005 | 07:51 PM
budhayes3's Avatar
PT's Slowest Truck
I left my key on when I did an oil change once and the same thing happened. After I drove it and cycled the key again, the light went off.
Old Feb 11, 2005 | 10:20 PM
ktmrider's Avatar
Battery or gas pedal clear for the oil message, either will do.
Like my father always asked, are you SURE?!? On the millionth time he asked me the filter was shoddy and puked oil all over the driveway. Needless to say I did not smart off to him for awhile on that one...
Corvette454l88
Sep 1, 2016 01:24 AM
Fast86z
Aug 23, 2015 12:35 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mzay
Jul 6, 2015 11:03 PM
